• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Employee
    rajsekarpillai
    Re: GF+ PE Pipe and fittings
    03-29-2012 06:46 AM in reply to: patpat78
    In AutoCAD Plant3D we use end connection rule to connect the parts. You can change the rule in the project settup -> End connections.
    e.g. Pipe + fittings+ valves looking for same ND to connect the parts.
    To fix your problem, Go to Catalog editor and change the ND size to 110 and update the same part in your spec and use it.
    Thanks & Regards,
    S. R. Rajasekaran
    Product Manager
    Plant Solutions - AEC
    Autodesk, Inc.
    Please use plain text.
