AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
GF+ PE Pipe and fittings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
I work in Autocad Plant 3D 2012 and I need to use GF+ PE Pipe and Fittings catalogue to create specs. Does anyone has faced this problem as me before.
Best wishes...
Re: GF+ PE Pipe and fittings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure about other people.. but I found most of the specs are missing too much to be useful.
so I made my own specs after modeling all the fittings needed.
"Do or do not... there is no try"
Master Yoda.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you can download complet gf catalog
http://autocad.autodesk.com/?nd=plant_content_pack
in europe section
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Autodesk Plant content team seeking your comment on the +GF+ content pack. Please read the readme file before downloading the content pack. Please let us know which materials of GF content do you use in your project?
http://autocad.autodesk.com/ama/orig/plant/README_
Looking forward to hearing from you.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you have any plans to create GF + PE catalogue? This one is missing.
Thank you
Bılent
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We are working on the priorities. Please vote your priority content pack requirement through Request Content Pack form.
http://autocad.autodesk.com/?nd=form__105
Thanks & Regards,
S. R. Rajasekaran
Product Manager
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i think in the GF catalog PVC there are some problemes
for diameter 63 for exemple when we generate iso or in the line name it says "63mm" not only "63" it's a big probleme for us because we cant use the spec wtih mm at the end of diameter... any idea ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please update the "NominalDiameterMap.csv" in your AutoCAD Plant3D root directory. To do that, Please download the attached file and replace existing file under "C:\Program Files\Autodesk\AutoCAD Plant 3D 2012 - English\".
Note: It is a good practice to back up the existing file before replacing it with the updated
version.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
it works thank's
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
other problem the csv file works fine but how it works with the nozle or steel valve
for exemple we have GF pipe and flange in 110mm but we use socle buterfly valve in nd100 in the reality it works but autocad doesn't want to combine these component ..
any idea ?
