• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    GF+ PE Pipe and fittings
    594 Views, 10 Replies
    03-14-2012 10:31 AM
    Hello
    I  work in Autocad Plant 3D 2012 and I need to use GF+  PE Pipe and Fittings catalogue to create specs. Does anyone has faced this problem as me before.
    Best wishes...
    Please use plain text.
    Valued Mentor
    JohnHolder
    Re: GF+ PE Pipe and fittings
    03-14-2012 04:16 PM in reply to: altargokhan
    Not sure about other people.. but I found most of the specs are missing too much to be useful.
    so I made my own specs after modeling all the fittings needed.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Active Contributor
    patpat78
    03-15-2012 01:06 AM in reply to: JohnHolder
    you can download complet gf catalog
    http://autocad.autodesk.com/?nd=plant_content_packs
    in europe section
    Employee
    rajsekarpillai
    03-15-2012 03:18 AM in reply to: altargokhan
    Autodesk Plant content team seeking your comment on the +GF+ content pack. Please read the readme file before downloading the content pack. Please let us know which materials of GF content do you use in your project?
    http://autocad.autodesk.com/?autodownload=../secure/protected/Georg-Fischer-PVC-CPVC-Sch40-PVC-Sch80...
    http://autocad.autodesk.com/ama/orig/plant/README__Georg_Fischer_PVC_CPVC_Sch40_PVC__Sch80_CPVC_Cont...
    http://autocad.autodesk.com/?autodownload=../secure/protected/Georg-Fischer-PVC-C-PVC-U-ABS-Content-...
    http://autocad.autodesk.com/ama/orig/plant/README_-_Georg_Fischer_PVC-C_PVC-U__ABS_Content_Pack.pdf
    Looking forward to hearing from you.
    Thanks & Regards,
    S. R. Rajasekaran
    Product Manager
    Plant Solutions - AEC
    Autodesk, Inc.
    New Member
    bgorucu
    03-16-2012 12:55 PM in reply to: rajsekarpillai
    Do you have any plans to create GF + PE catalogue? This one is missing.
    Thank you
    Bılent
    Employee
    rajsekarpillai
    03-16-2012 07:47 PM in reply to: altargokhan
    We are working on the priorities. Please vote your priority content pack requirement through Request Content Pack form.
    http://autocad.autodesk.com/?nd=form__105
    Thanks & Regards,
    S. R. Rajasekaran
    Product Manager
    Autodesk, Inc.
    Active Contributor
    patpat78
    03-21-2012 03:47 AM in reply to: rajsekarpillai
    i think in the GF catalog PVC there are some problemes
    for diameter 63 for exemple when we generate iso or in the line name it says "63mm" not only "63" it's a big probleme for us because we cant use the spec wtih mm at the end of diameter... any idea ?
    Employee
    rajsekarpillai
    03-22-2012 03:10 AM in reply to: altargokhan
    Please update the "NominalDiameterMap.csv" in your AutoCAD Plant3D root directory. To do that, Please download the attached file and replace existing file under "C:\Program Files\Autodesk\AutoCAD Plant 3D 2012 - English\".
    Note:  It is a good practice to back up the existing file before replacing it with the updated
    version.
    Thanks & Regards,
    S. R. Rajasekaran
    Product Manager
    Autodesk, Inc.
    Active Contributor
    patpat78
    03-22-2012 03:25 AM in reply to: rajsekarpillai
    it works thank's
    Active Contributor
    patpat78
    03-29-2012 06:38 AM in reply to: patpat78
    Hello
    other problem the csv file works fine but how it works with the nozle or steel valve
    for exemple we have GF pipe and flange in 110mm but we use socle buterfly valve in nd100 in the reality it works but autocad doesn't want to combine these component ..
    any idea ?
