• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Force iso onto one sheet
    1331 Views, 7 Replies
    12-27-2011 08:19 AM
    trying to get a line number to show on one iso. tried using "force iso onto one sheet" and moving the slider all the way up. i have checked all the components to make sure they are all on the same line number and are not unassigned. including connectors. what the heck am i missing...<sigh>
    screen caps attaached.
    Please use plain text.
    Re: Force iso onto one sheet
    12-27-2011 08:20 AM in reply to: thebearjed
    screen cap #3
    P.S.
     I need this resolved ASAP.
    ricardo.janesko
    12-28-2011 01:59 AM in reply to: thebearjed
    I also have this problem. When generating an isometric of a single line, the plant dividing the line in several isometrics (even selecting "force iso onto one sheet").
    Is there any way to reduse the number of sheets? In the 2011 version of the program, the same line was generated in a single sheet.
    12-28-2011 05:48 AM in reply to: ricardo.janesko
    seems to be a pretty common problem. so far it seems that getting rid of spoolgen was a bad idea.
    12-28-2011 07:08 AM in reply to: thebearjed
    I have a sloution. open the isoconfig.xml file and find this section...
    <!-- 'MaxDirectionChanges': controls the maximum allowed direction changes for a spool.
    Exceeding which will start -->
    <!-- another spool. Setting this option to zero will ignore it. -->
    <!-- 'MaxWeight': Defines the maximum weight of all components in the spool. It is not taken
    into account when setting to '0'. -->
    <!-- 'MaxPipeLength': A special case in spool splitting. Normally the max pipe spool is 20ft or
    6m. -->
    <!-- Set MaxPipeLength to 0 to ignore the option. -->
    <Spool SpoolSplitMethod="OnSize" SizeLimits="96 480 96" OverflowLength="6"
    MaxDirectionChanges="0" MaxWeight="0" MaxPipeLength="240" PropertyChange="PIPING-SPEC"
    set the field in red to 0.
    now find this section...
    'CongestionLevel': (1.0 - 3.0); CongestionLevel defines the congestion level that is
    allowed in an iso drawing. -->
    <!-- 1.0 allows the greatest congestion. 3.0 allows the least congestion. -->
    <Auto SplitSymbol="SplitMark" SpoolSplit="false" IdentifySpools="true" SplitOnCongestion="true"
    CongestionLevel="1" />
    set the field in red to 1.
    save and close. go back to your model and produce an iso. i still check the "force onto one sheet" box. this seems to fix the problem to some degree. however, very large lines still split but for the most part they come out on one sheet.
    01-04-2012 09:01 AM in reply to: thebearjed
    just to clarify it HELPS but does not in any way fix the problem.
    why is there an option to force onto one sheet if it doesn't work??? just saying...
    09-18-2012 08:40 AM in reply to: thebearjed
    I am having the same issue as well.  How is this not fixed or working properly?  "force iso onto one sheet" seems like it should work exactly as it sounds, but i am still getting multiple sheets when i run the line number.  Very aggravating.
    09-18-2012 08:58 AM in reply to: eliszymanowski7369
    what release are you running. we have upgraded to 2013 and it SEEMS to be working properly with the exception of creating a second iso for overflow of the bill of materials when needed.
    here are edits that i made to the .XML file
    6m. -->
