• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    Font Size of Line Numbering and cutlist
    246 Views, 8 Replies
    04-23-2012 09:07 AM
    I am having a trouble in setting the font size of Line Number Annotion displayed in the Isometric. Even after I keep the text style height as 2.5mm, in isometric it is getting displayed with a height of only 1.7mm around. How to fix this, as-similar the annotation text height of cutlist is displaying around only 1.2mm even after this was changed in the Iso-symbol editor to 2.5mm.
    Arun
    Please use plain text.
    Active Member
    Re: Font Size of Line Numbering and cutlist
    04-24-2012 09:39 PM in reply to: krisharun84
    Attached herwith the Isometric drawing marked with clarifications seeked for clarify.
    Active Member
    04-25-2012 07:22 AM in reply to: krisharun84
    Tomislav Golubovic- I am awaiting for your reply, as I didn't get the answer from Autocad partner to our company.
    Employee
    TomislavGolubovic
    04-25-2012 10:09 PM in reply to: krisharun84
    So when you edit the Isometric Style, and go into the Iso Theme's, you've nominated the Annotation size as 2.5mm?
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Active Member
    04-26-2012 08:00 AM in reply to: krisharun84
    Yes, did, you can check your own sample isometric and see, even if u keep the text height as 2.5mm, the font size of line numbering is not getting changed.
    Active Member
    04-27-2012 09:05 AM in reply to: krisharun84
    I don't understand why more time is being taken for reply from Autodesk side, I always expect a genuine support engineer to answer for a query in 1 or 2 days if not the time frame for answering should to be informed. Keeping silent is what?????
    Employee
    TomislavGolubovic
    04-28-2012 05:12 AM in reply to: krisharun84
    Actually I've been chasing it up and have to confirm settings, plus its the weekend here.
    Tomislav Golubovic
    Product Support
    Venkatesan.A
    04-30-2012 04:33 AM in reply to: krisharun84
    Arun,
    Can you try the settings mentioned in the attached document and let me know if that is what you were looking for?
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Venkatesan.A
    Support Specialist
    Product Support
    Distinguished Contributor
    Ahmed1081975
    05-05-2013 09:38 PM in reply to: TomislavGolubovic
    Hi Autodesk Support,
    I thing the Autodesk People not understand what we are meant,
     Our Problem When we are using the option in the Isometric Settings to show the Part No. Or Tag No. Or .....,
     As isometric whine generating the Isometric drawing there are no options for Changing Size From 1.7 to 2.5
     Because it’s Already 2.5mm by default, Hope Understand our Problem
    Ahmed Helal
