• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    Flow Arrow On Isometric 2012
    921 Views, 9 Replies
    10-20-2011 04:28 PM
    There is a dimension appears on Flow arrow on Isometric. and if the line is insulated it also gives an Insulation break. is there a setting to turn this off?
    Please use plain text.
    Re: Flow Arrow On Isometric 2012
    10-31-2011 11:19 AM in reply to: rlpacle
    guys, anyone? i havent figure out how to turn off this very special feature..
    Employee
    VickyADSK
    11-01-2011 01:39 AM in reply to: rlpacle
    Turn off Insulation break annotation:
    Go to IsoConfig.xml from project style folder. e.g. Project name\Isometric\Check_ANSI-B
    Comment out selection below string or Delete it.
    <PropertyBreakerScheme Name="InsulationLimit" AnnotationStyle="SpecBreak" Tag="Left Right" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="NotBoltOrWeld" Field="HasInsulation" DefaultAnnotationStyle="Standard" DefaultL-->eaderStyle="Always" WordWrapLimit="10" EnableMultiple="true" />
    Btw, the issue regarding dimension for Flow arrow has been identified. Thanks for your reporting it.
    Vicky
    Autodesk Plant Solutions
    Valued Contributor
    neonade
    11-17-2011 08:06 PM in reply to: VickyADSK
    Hi Vicky,
    Is your reply the answer to the flow arrow issue?
    Thanks and regards
    Employee
    VickyADSK
    11-17-2011 09:09 PM in reply to: neonade
    My above reply is to solve insulation annotation for flow arrow.
    Remove dimension of flow arrow:
    Go to isoconfig.xml file to modify, e.g. Project\Isometric\Check_A2\isoconfig.xml, add below red string.
    <Filter Name="Fitting" Value="NOT (Type = 'Pipe' OR Type = 'Gasket' OR Type = 'REINFORCEMENT-PAD' OR Type = 'Flange' OR Type = 'Bolt' OR Type LIKE 'Valve*' OR Type = 'Olet' OR Type LIKE 'Instrument*' OR Type = 'Support' OR Type LIKE 'Elbow*' OR Type LIKE 'Cross*' OR Type = 'Weld' OR Type LIKE 'Tee*' OR Type LIKE 'Y-*' OR Type = 'FLOOR-SYMBOL' OR Type = 'FLOW-ARROW')" />
    The issue has been fixed in our next release.
    Thanks very much.
    Vicky
    Product Support
    11-21-2011 03:11 AM in reply to: rlpacle
    The issue where a dimesion is being placed for the flow arrow has been escalated to our development team so it is something that is under current investigation.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Active Contributor
    OmarGT
    01-03-2012 08:17 PM in reply to: DanScales
    Excuse me, is the placed-dimension issue already solved? Thanks in advance
    Employee
    VickyADSK
    01-03-2012 08:23 PM in reply to: OmarGT
    Yes. We have already fixed  both above 2 issues in Plant 3D 2013. Thanks for your concern!
    Vicky
    08-27-2012 12:26 PM in reply to: VickyADSK
    What about in 2012? is there a work around or Hot fix for this problem? we're currently using 2012 on our project. thanks!
    Valued Mentor
    Rich.O.3d
    10-08-2012 04:50 PM in reply to: VickyADSK
    Ok...i have this flow arrow edit inplace.
    I have a line that starts with a section of Rubber lined pipe from the pump then after FIT/DIT, the line continous an in a poly pipe spec.
    on the poly section, flow arrows are aok
    on the rubber lined section, the flow arrows are dimensioned!
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
