• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Flanged Piping Questions .
    482 Views, 7 Replies
    10-03-2012 01:55 PM
    Hello
    I am trying to work on Pipe connection settings to allow auto flange but no success.
    When I try to connect or rout from a nozzle that is configured as FF (Facing RF ou FF), it doesn't add automatically a flange and the same when I insert a flanged valve or equipment.
    I tried to see some forums but doesn't help too much.
    Can anybody help, please?
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Flanged Piping Questions .
    10-03-2012 07:59 PM in reply to: nawfel.bouzayani
    Can you post a screen shot of your compound joint settings?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    10-05-2012 08:13 AM in reply to: nawfel.bouzayani
    I think that I have a problem in how to configure the Piping Connection Settings in the attached file.
    Can any one tell me how shall I configure it to get the autoflanged connection fixed.
    Thank you
    *Expert Elite*
    dave.wolfe
    10-05-2012 08:20 AM in reply to: nawfel.bouzayani
    Sorry, forgot to ask the basic question first...just to make sure we're on the same page.  Are you sure you have FF flanges in your spec?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    10-05-2012 09:14 AM in reply to: dave.wolfe
    I have FF flanges and facing RF.
    10-09-2012 12:49 PM in reply to: nawfel.bouzayani
    This is the spec I am working on.
    10-30-2012 09:14 AM in reply to: dave.wolfe
    Does anybody has answer for this problem?
    Thank you
    Valued Mentor
    Rich.O.3d
    10-30-2012 07:13 PM in reply to: nawfel.bouzayani
    please try setting your autoflangejoint back to how it came out of the box
    then at your flanged joint, modify and remove tick from facing in the required match box.
    this will allow you to connect a FF flange to a RF flange, it will give you a warning just pick ok
    if you dont want the warning, then delete facing from the required matches completely
    i notice you also have created the possibility for a THDM to connect to a THDM and a THDF to a THDF also you have THDM connecting to a FL etc ...are you sure you want these types of connection?
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
