AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Flanged Piping Questions
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Right, you have to select the pipe first.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Fantastic! That's what I've been looking for. Thanks! Is there a way to move that weld after it's placed? I don't see any grips on it...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can do a stretch command around the fittings...yea, remember AutoCAD?! ![]()
Every now and then you can still use those commands.
Isaiah 57:15
ECAD, Inc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ahh, the stretch command... That works fairly well. What I was hoping for was a way to select the joint (weld) and move it a specific distance from the other end of the pipe using dynamic input. Basically setting the cut length of the pipe by moving the weld. I can do it the other way though... select the pipe and move the free end to the desired distance from the weld. Not as ideal but will work fine.
Thanks again for all your help!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is a little glitch: I ran an ISO with my two pieces of pipe with the "weld" joint... the iso schematic shows and dimensions both pipes but the Bill of Materials combines them as one piece... Hmmmm
At least I'm closer than I was earlier!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did you do a cut list?
Isaiah 57:15
ECAD, Inc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure how to do a Cut List, but it's correct in the Data Manager... it shows two separate line items for the pipe with correct cut lengths.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Cut list is in the Iso Styles, when you setup the border and the tables.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So yes, the Cut Piece List identifies the pipe correctly. I think I would have to include both the BOM and Cut List on my Isos which is fine... but is there a way to eliminate pipe out of the BOM... that way I don't duplicate material in the list.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Peter,
I've seen you create a flanged pipe.
What is the procedure for this.
I've have try this, I cannot get this to work.
I still have pipe with no flanged.
Here is my procedure.
1. create new component.
2. populate size parameters.
3. save catalog.
4. add to spec.
Is there anything that I am missing?
Thanks in advance.
