• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    *Expert Elite*
    dave.wolfe
    Re: Flanged Piping Questions
    03-08-2012 12:30 PM in reply to: jpeters
    Right, you have to select the pipe first.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Please use plain text.
    jpeters
    03-08-2012 12:40 PM in reply to: dave.wolfe
    Fantastic!  That's what I've been looking for.  Thanks!  Is there a way to move that weld after it's placed?  I don't see any grips on it...
    *Expert Elite*
    dave.wolfe
    03-08-2012 12:44 PM in reply to: jpeters
    You can do a stretch command around the fittings...yea, remember AutoCAD?! :smileyhappy:
    Every now and then you can still use those commands.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    jpeters
    03-08-2012 12:58 PM in reply to: dave.wolfe
    Ahh, the stretch command...   That works fairly well.  What I was hoping for was a way to select the joint (weld) and move it a specific distance from the other end of the pipe using dynamic input.  Basically setting the cut length of the pipe by moving the weld.  I can do it the other way though... select the pipe and move the free end to the desired distance from the weld.  Not as ideal but will work fine.
    Thanks again for all your help!
    jpeters
    03-08-2012 01:10 PM in reply to: jpeters
    Here is a little glitch: I ran an ISO with my two pieces of pipe with the "weld" joint... the iso schematic shows and dimensions both pipes but the Bill of Materials combines them as one piece... Hmmmm
    At least I'm closer than I was earlier!
    *Expert Elite*
    dave.wolfe
    03-08-2012 01:11 PM in reply to: jpeters
    Did you do a cut list?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    jpeters
    03-08-2012 01:15 PM in reply to: dave.wolfe
    Not sure how to do a Cut List, but it's correct in the Data Manager... it shows two separate line items for the pipe with correct cut lengths.
    Employee
    TomislavGolubovic
    03-08-2012 02:55 PM in reply to: jpeters
    Cut list is in the Iso Styles, when you setup the border and the tables.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    jpeters
    03-09-2012 05:56 AM in reply to: TomislavGolubovic
    So yes, the Cut Piece List identifies the pipe correctly.  I think I would have to include both the BOM and Cut List on my Isos which is fine... but is there a way to eliminate pipe out of the BOM... that way I don't duplicate material in the list.
    Thanks!
    Active Member
    06-07-2012 08:49 AM in reply to: dave.wolfe
    Hi Peter,
    I've seen you create a flanged pipe.
    What is the procedure for this.
    I've have try this, I cannot get this to work.
    I still have pipe with no flanged.
    Here is my procedure.
    1.  create new component.
    2.  populate size parameters.
    3.  save catalog.
    4.  add to spec.
    Is there anything that I am missing?
    Thanks in advance.
