- Mute
- Permalink
- Report
I’m fairly new to Plant 3D (2012) and have a couple questions about flanged pipe:
1.) I can’t see a simple way to create a Flanged x Plain End pipe without using custom geometry. This configuration doesn’t seem to be available when creating a new component. I can create a pipe with a FL and PL port, but it graphically still shows two flanges in the model. It seems like this should be a standard option…
2.) I’m looking for a way to connect two Flange x Flange pipes together without losing the flange connection in the middle. An example would be a 20’ run of flanged pipe. Say I can only get this pipe in a 17’-6” length. I would need an intermediate joint and two spools of pipe to build this. I’ve tried creating a flange component but it ends up changing one of the pipes to PLxPL, adds other un-needed parts and duplicates gaskets. Is there a “break” command that forces an intermediate joint?
On a related note, I would love to see the addition (if it doesn’t already exist) of a Max Pipe length parameter in the catalog that would limit the length of pipe drawn. When this limit is reached on a run, a flange connection would be added and a new pipe began. This parameter should be per size since some manufactures have different maximum lengths based on nominal diameter. Flanged US Pipe is a good example.
Thanks! -Jason
