• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    vannmannen
    Fittings wil not move along the pipe.
    165 Views, 2 Replies
    08-30-2012 06:31 AM
    See attached pictures. My fittings are detach from the pipe when I try to move it and snap to equipment.
    I have tried all kinds of ortho + snap setting, but the fittings will not work as stated in the manual.
    Please advice
    Please use plain text.
    dave.wolfe
    Re: Fittings wil not move along the pipe.
    08-30-2012 08:14 AM in reply to: vannmannen
    To move it in that type of scenario I use point filter.  Keep the nearest osnap on, grab the center grip on the main run, use the point filter for the main run of pipe, and then pick the nozzle you want to line it up with.  pick the center grip on the tee for the last point filter prompt and it should move to the correct location.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Mentor
    Rich.O.3d
    08-30-2012 04:03 PM in reply to: vannmannen
    the point you pick to move the fitting to needs to be a point on the actual line.
    I would pick the centre grip node on the tee then
    shift+rmb pick the 'from' snap
    pick the centre of the flange on the equipment as your from point
    shift+rmb pick the 'perpendicular' snap
    pick the pipe line with the tee in it pretty much anywhere on its length
    'voila'
    filters will work also, but I find the 'from' snap VERY handy
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
