• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Accepted Solution
    Fatal Error on Custom Parts AutoCAD Plant 3D 2013
    263 Views, 2 Replies
    06-02-2012 02:15 PM
    I am getting a fatal error when i click on 'Custom Parts'. This was working a few weeks ago but since has been crashing AutoCAD. Short of reinstalling I am unsure of what to do. The Fatal error is alway and "Unhandled access violation reading 0x0000 exception at *******" the last part is always different but i attached 4 of the errors i have seen today. It seems to make no difference what Spec or even what project i am in.
    Please use plain text.
    Valued Contributor
    Re: Fatal Error on Custom Parts AutoCAD Plant 3D 2013
    06-05-2012 11:02 AM in reply to: rybobales
    I have experienced the same problem after installing P3D 2013. I ended up tracing the problem back to P3D 2013 not properly migrating all of my specs from P3D 2012, especially my custom part catalog and specs. Check and make sure that all of your specs and catalogs have been properly migrated to 2013. After doing this the error went away and custom parts are working fine again.
    hope this helps,
    Chad
    Member
    06-05-2012 12:19 PM in reply to: chad70811
    Worked like a charm! I'm not sure how, as that it would do that in the default project with no 2012 specs, But after i updated all specs and catalogs and saved them it did just as it should!
    Thanks a lot!
    Ryan
