• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    marodi
    FLANGED PIPE CONNECTION
    116 Views, 0 Replies
    08-21-2012 05:36 AM
    Hello Everyone!
    How can you make the following:
    I want to put down pipe segments(in a straight line), and I want them to be separated with
    flanged connections. I want the flanges to be created automatically(not putting manually,
    after the pipe creation). Is it possible?
    I tried:
    1. Pipe with FL ports, but after that, the software put only on side of the flange, with a gasket,
    and a bolt set, and no other side of the flange.
    2. Plant3D parametric graphics(v2013)(with flange endings, but this does not seems to look good, when I put them
    down, there are empty spaces between the pipe's end and the gasket.
    Can anyone write me the proper way of doing this?
    Thank You!
    Please use plain text.
