• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    JohnHolder
    Accepted Solution
    FATAL ERROR: *Urgent*
    360 Views, 2 Replies
    10-15-2012 02:39 PM
    FATAL ERROR: Unhandled Access Violation Reading 0xfffffff8 Exception at efdd241ah
    Crashes on start up.....
    Repaired - no change
    Re-installed - no change
    When it initially crashed, I renamed the project file I was working and added "bak" to it, in case it was causing the issue.
    ACad / revit / ASD all start up without an issue, it is JUST P3D I am currently unable to work.
    I put in a ticket, but does anyone have a suggestion aswell?
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: FATAL ERROR: *Urgent*
    10-15-2012 04:40 PM in reply to: JohnHolder
    Did you clear the graphics cache:
    http://www.pdoteam.com/2012/06/fatal-error-on-plant-3d-startup/
    and the local data cache:
    http://www.pdoteam.com/2012/03/plant-3d-startup-hanging/
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Mentor
    JohnHolder
    10-15-2012 04:55 PM in reply to: dave.wolfe
    Graphics Cache!
    I backed up the directory then deleted everything inside.
    Thank you very much Mr. Wolfe!
    Master Yoda.
