• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Accepted Solution
    Export from p3d to inventor
    380 Views, 3 Replies
    09-05-2012 01:55 PM
    I know this a strange workflow. Our client has only inventor. I need to make a pipedesign in a factory. I want to use my plant 3d software. After the projec at the client he needs to maintain and edit the model for future purposes. Is it possible to export my plant 3d work to inventor letting my client edit the piping. It is no problem that data and connections were lost. What file format is best?
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Export from p3d to inventor
    09-05-2012 03:41 PM in reply to: snijdam
    You can import a 'dumb' Plant3D model into Inventor. Type EXPORTTOAUTOCAD and create a new 'dumb' DWG file of your Plant model.
    As for continued editing, it will be limiting in what they can do, if anything in Inventor with the Plant entities.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Valued Mentor
    Rich.O.3d
    09-05-2012 03:58 PM in reply to: snijdam
    consider:
    doing the piping in Inventor Pro (routed systems)
    then dump PCF from inventor and import into Plant3d for creating ISO
    not sure if it will fly, but in theory, and from the autodesk advertising blurb, it should be possible
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Product Support
    gersteb
    09-14-2012 05:46 AM in reply to: snijdam
    Hi snijdam,
    Could Tomislav help you? Please, mark it as solved. Otherwise let us know.
    Bernd
    Bernd Gerstenberger
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
