• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Export catalog with unique id
    217 Views, 5 Replies
    10-08-2012 05:41 AM
    I would like to export a catalog (pcat) to Excel with a unique identifier field as one of the columns. Is there any way to achieve this using Spec Editor on Catalog Builder?
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Export catalog with unique id
    10-08-2012 05:47 AM in reply to: tmccar
    The default unique Identifier is the PnPID column which is exported.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    10-08-2012 06:46 AM in reply to: dave.wolfe
    It's not unique unfortunately - you can have a part from "Supplier X" and apart from "Supplier Y" with the same PNPid. I would like to be able to distinguish between them.
    *Expert Elite*
    dave.wolfe
    10-08-2012 07:11 AM in reply to: tmccar
    Actually, it is unique for the catalog.  If you have the same PnPID in a spreadsheet in excel, I suspect the last entry will overwrite the first one.  The PnPID is used by the program to know which database row should get updated.
    Spoiler
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    10-15-2012 03:14 AM in reply to: dave.wolfe
    I would like to have a unique id across all catalogs - what is the best way to achieve this? (I would like to leave the catalogs intact if I can).
    *Expert Elite*
    dave.wolfe
    10-15-2012 05:13 AM in reply to: tmccar
    You can do an export to Excel and then use the Item Code (Part Number) field.  You'll have to fill it in manually for every item (unless you want to use some sort of calculated field).
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
