AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Export catalog with unique id
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would like to export a catalog (pcat) to Excel with a unique identifier field as one of the columns. Is there any way to achieve this using Spec Editor on Catalog Builder?
Re: Export catalog with unique id
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The default unique Identifier is the PnPID column which is exported.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It's not unique unfortunately - you can have a part from "Supplier X" and apart from "Supplier Y" with the same PNPid. I would like to be able to distinguish between them.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Actually, it is unique for the catalog. If you have the same PnPID in a spreadsheet in excel, I suspect the last entry will overwrite the first one. The PnPID is used by the program to know which database row should get updated.
Isaiah 57:15
ECAD, Inc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would like to have a unique id across all catalogs - what is the best way to achieve this? (I would like to leave the catalogs intact if I can).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can do an export to Excel and then use the Item Code (Part Number) field. You'll have to fill it in manually for every item (unless you want to use some sort of calculated field).
Isaiah 57:15
ECAD, Inc.
