• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    HEANRorkraft
    Accepted Solution
    Exclude parts in Report Creator
    299 Views, 2 Replies
    12-12-2012 04:29 AM
    I have a problem with Report Generator that i can't figure out. I am currently in a project where I am connecting to existing pipes. I have modeled these existing pipes but I don't want them in my MTO (of course). I have set the properties for these pipes to "existing" but the still appear in the MTO. The total length of pipes is too much.
    How do I exclude pipes and other equipment from the MTO automatically?
    Please use plain text.
    Product Support
    Re: Exclude parts in Report Creator
    12-13-2012 03:08 PM in reply to: HEANRorkraft
    First, do you have access to the Report Designer Manual? Please refer to this forum link and the post by Jason Drew, he provides a link to access the manual.
    http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Report-Creator/td-p/.UMpZaG_Ae_w
    The field I used in the Pipe properties was Status. There you can assign the pipe as either New, Existing or Demolition.
    Then, I opened Report Creator and I created a new report based off of my existing 3D Parts report. You can either generate a new one or base it off another existing report depending what you are wanting to do. Then I selected Edit and Edit Report layout. I added a new column to include the status.
    You will then need to setup a filter. This filter will only place the New items you set in the Status.
    Now I will run the default 3D Parts report. Pay notice to the total pipe lengths.
    Now the new report that filters Status for New items.
    Hopefully, this guides you in the direction you needed.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    HEANRorkraft
    12-13-2012 11:21 PM in reply to: quentin.contreras
    Mr. Contreras,
    Thank you for a very detailed reply. This is exactly the kind of answers we want when we post questions here!
    Regards
    Henrik Andersson
    Sweden
