Dear all,
We have noticed an issue on one machine regarding a project we have started in Plant 3D. The error that comes up when we open the project is "INTERNAL ERROR: !dbobji.cpp@7319 eNot Open For Write". Has any one come across this? Does anyone out there have any best practice documents etc on project setup?
The reason for asking is that now when we open Plant 3D, the same project tries to open but crashes everytime and closes Plant 3D. The only way to get it working again is to delete the USER Key in the registry and fire up the secondary installer for Plant 3D... This removes the link and loads the default project template. We can open the project again but unfortunately we end up in the same position...
Duncan
Solved by ukdxb012. Go to Solution.
Hello Everyone,
I am currently receiving the following error, !dbobji.cpp@8440: eNotOpenForWrite
I try opening the project file which basically includes line work and some alignments. There may be some corridors and data short cut information, aside from these items some x-references. Im not sure what could possibly be causing the internal error.
Within our company, we just recently converted to 2018 Autocad. This particular file is being used with Civil 3D. A few ideas have been tossed around here about resolving the problem, which has been to open all of our base files (files that we are x-referencing into this particular file with the internal error) and recover, audit and purge. This really has not made any difference in the problem file.
My guess is this is a corrupt x-ref somehow, but not sure which one, since i cannot access the file and i have recovered all of the xrefs. Another would be the data shortcuts that i may have within the file. It seems i have difficulty opening any file that may contain data shortcut info or profile from the type of files i have tried opening for this project.
The solution below may not work since this is in Civil 3D and the number to the problem is @8440...but any help or description as to why this happens would be greatly appreciated, maybe i can find a work around. I have also attached the file in which i am having difficulty opening. Maybe you will have better luck opening it. FYI 2018 version
Hugo
