• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    vannmannen
    Equipment Nozzle Modification
    314 Views, 10 Replies
    08-07-2012 04:19 AM
    This topic has been seen elsewere but without any solution.
    I can create an equipment, but when I click on the 'edit nozzle' pen, nothing happens.
    The command line shows:
    Command:
    Specify point location or [Base point/Undo/eXit]: *Cancel*
    Command: _.PlantNozzleEdit
    Command:
    And this is the same output that comes on the Plant 3D - Equipment video on youtube, but I do not get the nozzle menu.
    In addition no menu comes up when I use the 'modify equipment' button.
    The command line gives me this:
    Select Equipment to modify:
    Invalid selection. Only one equipment item can be selected
    So I am stuck with a pump that only has standard size/rating on the nozzle.
    Please help me !!!
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Equipment Nozzle Modification
    08-07-2012 05:34 AM in reply to: vannmannen
    Try changing the visual style.  I've had it happen a couple times, and switching the visual style got it working.  I haven't tried it, but regenall may work too.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Active Contributor
    vannmannen
    08-07-2012 05:50 AM in reply to: dave.wolfe
    Thank you Dave.
    I have tried all the visual styles but none of these give any improvement.
    Neither did the regenall command :smileysad:
    *Expert Elite*
    dave.wolfe
    08-07-2012 06:21 AM in reply to: dave.wolfe
    Can you post the dwg?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Active Contributor
    vannmannen
    08-07-2012 06:25 AM in reply to: dave.wolfe
    Of course I can.
    This is the centrifugal pump with in standard configuration.
    Tnx.
    Active Contributor
    vannmannen
    08-07-2012 07:02 AM in reply to: vannmannen
    ...thats made in 2012 version
    Active Member
    10-26-2012 03:21 PM in reply to: vannmannen
    Did this issue ever get resolved?  I am having the exact same problem!
    Active Contributor
    vannmannen
    10-26-2012 04:41 PM in reply to: hwood818
    Sent from my iPhone
    Active Contributor
    vannmannen
    10-26-2012 05:47 PM in reply to: hwood818
    Yes, the problem is solved.
    First of all my brand new laptop had some severe bios issues. We ran a check on it and had to reset the whole thing. The program was slow and this bios thing might have been the reason for the nozzle issue. In addition I re-installed/repaired the program and now it works just fine. In your case, I would try the re-installation and see if this helps.
    Valued Mentor
    Rich.O.3d
    10-30-2012 07:25 PM in reply to: vannmannen
    i was having the same issue, an update to the graphics driver fixed it
    the last nvidia tesla driver was a bit flakey, the newest one solved a few issues.
    ps i find REGEN3 works better than regenall (its specific for regenrating solids I think)
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
