• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Equip Nozzle Tags
    126 Views, 5 Replies
    09-17-2012 02:20 PM
    I have a new equipment with a boot. Nozzles are comprised of both equip generated and attached plant entities. That have nozzles. I want the nozzle numbers to match my purchase drawing. I can't figure out how to modify the nozzle numbers to have alphas (6A-6B) or number them to skip a number so assigning them with attached component nozzles can be done.
    Please use plain text.
    Ahmed1081975
    Re: Equip Nozzle Tags
    09-17-2012 09:07 PM in reply to: breckanderson
    I have Same Proplem I can't Edit the Nozzle No. For Example  i have Nozzle (N6) i want Change To (N6B)
    any one can help Us please
    Ahmed Helal
    Employee
    TomislavGolubovic
    09-18-2012 01:06 PM in reply to: Ahmed1081975
    Press CTRL when clicking the nozzle, then you get a pencil symbol, which lets you edit the nozzle.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Member
    09-18-2012 01:59 PM in reply to: TomislavGolubovic
    That does not allow you to change the nozzle number. You can only change the location and type. I have learned that I need to set up a custom equipment tag in the project set up. See Jason video listed below.
    I recorded a video with some info about configuring the nozzle tags for Plant 3D:
    Member
    09-18-2012 01:59 PM in reply to: Ahmed1081975
    Try this
    Employee
    TomislavGolubovic
    09-18-2012 04:58 PM in reply to: breckanderson
    I did the exact same and get the result (I think) you're expecting.
    Send me a PM with your email and we can take it from there.
    Tomislav Golubovic
    Autodesk, Inc.
