• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Eshleman78
    Editing BOM in Plant3D Isometrics
    686 Views, 9 Replies
    12-06-2011 07:48 AM
    How do I change the text color in the BOM in my Plant3D 2012 Isometric setup?  It is currently 0,255,255.  I've tried changing the Table Style text color and nothing changes.
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Editing BOM in Plant3D Isometrics
    12-06-2011 10:26 AM in reply to: Eshleman78
    Edit the cell, unlock it and change the color in the Properties
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Eshleman78
    12-06-2011 12:05 PM in reply to: Eshleman78
    Thanks for the reply, I just found the solution in an older post also.
    dustyray2010
    12-07-2011 02:09 AM in reply to: Eshleman78
    Use a crossing window to select all cells, then go to properties, and select color. You will have to do this on every iso.
    I haven't been able to change color in iso setup without losing the formula req'd.
    Dusty
    Active Contributor
    02-09-2012 06:04 AM in reply to: dustyray2010
    Hi, isn't there an easier way to change this in the iso set up for not having to do it in every drawing ?
    also when I plot the drawing I can control all the colors with the plot style table but not the BOM txt, even with monochrome it stays with 0,255,255
    *Expert Elite*
    dave.wolfe
    02-09-2012 07:55 AM in reply to: alvaro.nimasco
    Edit the table style in the bom isometric setup and change the data text color to by layer.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Contributor
    neonade
    07-29-2012 06:53 PM in reply to: dave.wolfe
    Please show step by step on how to change the font color on the data cells, I am having quite difficulty in doing this.
    Thanks.
    Valued Contributor
    neonade
    07-29-2012 07:15 PM in reply to: neonade
    I think I all got it messed up when changing the text color by layer by selecting the words and changing it on the text editor which is not right as shown below.
    What I have found out correct way is to select the entire cell row then unlocked it, then change the color on the properties (Ctrl+1), on the Content area, change the text color :-) and it works,
    Active Member
    12-10-2012 06:00 AM in reply to: dave.wolfe
    Hi Dave,
    I know this post is veeeeery old, but busy with setups in P3D 2013 and cannot get my "color" template to print in B&W?
    I have tried everything!
    Please help!
    -=StevieWonder=-
    "Trust me, I'm a draftsman"
    New Member
    01-17-2013 05:45 AM in reply to: Eshleman78
    Hi!
    You can solve the problem by unlocking the cells, Mark the cells and click on cell_locking and tick in unlocked:
    Like this.
    After that right click and click on properties and change text color to e.g white like this:
    After this you once again tick in the Content and Format locked in the ribbon / Cell Locking icon.
    Then click Return to Project Setup and click Save changes to "iso.dwt" when that message comes up
    Hope it helps
    /Stefan
