Edit Equipment Nozzles in Plant 2012
Message 1 of 11
We migrated from Plant 3D 2011 to 2012 and have the following issues with equipment nozzles:
1.  Equipment that was migrated from 2011, when we try to edit equipment nozzles, we do not get the "pencil". When we try to select the nozzle by itself, the whole equipment hilites.
2. The same thing happens with equipment that we create in 2012.
How are we suppose to select the nozzle on equipment in 2012 and edit these nozzles?
Replies (10)
Message 2 of 11
To edit the nozzle you should press control and select the nozzle, so the pencil will appear to edit.
Ricardo
Message 3 of 11
Thank you Ricardo...this was helpful to me as well.  However, I cannot find a way to DELETE a nozzle that was previously created without recreating the entire tank and nozzles from scratch.  How do you delete a previously created nozzle?
Chuck
Message 4 of 11
For you delete a nozzle, the procedure is the same. With the CTRL key you select the nozzle and click delete. If not, try to isolate the tank and repeat this procedure.
Ricardo Janesko
Message 5 of 11
Excellent!  Ctrl > Select Nozzle to highlight > DELETE
I was looking for a delete button AFTER clicking on the pencil to edit but instead of clicking on the pencil you just hit the delete button.  Thanks
Message 6 of 11
batone79
HI, Ricardo I hope you can help me about this.
I created a Equipment and adding a Nozzle, I can not change Spec and Size, every time do the same Nozzle size and Spec.
How can I change Nozzle´s spec and size?
I show you in the img added to this post, where you can see in a Red box the spec to change for the Green box and don´t do it.
thanks.
Message 7 of 11
try clicking on the item you show in green box...it should turn blue to show it has been slected then apply and check again
Message 8 of 11
batone79
HI, thanks for your replay, thats works...thanks and sorry for the inconvenience...
Message 9 of 11
Has the original modify nozzle problem been solved? Where the nozzle doesn't highlight and the pencil doesn't appear. I can create equipment then edit the nozzles but later the edit procedure stops working.
Message 10 of 11
TomislavGolubovic
Are you pressing CTRL when you click on the equipment nozzle?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 11 of 11
Hi Ricardo
I hope you can solve this one:
I changed values on field "Change Location" fro the selected nozzle, but even when I don't select CLOSE  button, this window to make changes suddenly closes by itself and the nozzle don't keep the new values!
What I'm supossed to do?
Thanks a lot in advance! Smiley Happy
