• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    ERROR in Catalog Builder - Creating block based part
    402 Views, 5 Replies
    10-20-2012 03:54 PM
    I want to create my custom Tee catalog
    1) I draw a tee in Inventor 2013
    2) Export it as *.adsk (also I've tried as *.dwg)
    3) Import it in Plant3D 2013, convert to Block, convert with PLANTPARTCONVERT and save this file.
    Then when I'm trying to open it in Catalog Builder I have: "Invalid Dwg file :eNotAllowedForThisProxy". What is wrong?
    Please, help me to finish my job!
    Anatol D. Gutak
    Please use plain text.
    Product Support
    Venkatesan.A
    Re: ERROR in Catalog Builder - Creating block based part
    10-23-2012 01:19 AM in reply to: agutak
    eNotAllowedForThisProxy exception error means that the drawing contains some hidden Proxy objects, can you purge the dwg and try again?
    Venkatesan.A
    Support Specialist
    Product Support
    Active Member
    fedorafly
    Mark for learning.
    10-31-2012 10:58 PM in reply to: agutak
    Mark for learning.
    11-01-2012 08:59 AM in reply to: agutak
    I've tried all this but it doesn't work.
    I found a solution for this problem. I export my inventor assembly as *.sat, then import it in Plant3D and then convert to block and plantpartconvert.
    In this way I can import my created *.dwg in Catalog Builder
    Anatol D. Gutak
    Valued Mentor
    Rich.O.3d
    11-01-2012 06:23 PM in reply to: agutak
    my method:
    from your part in inventor
    hit save as...Save Copy As
    select autocad dwg file from the file type pull down
    select options....detick all but solids
    this will give you a nice autocad object, open the dwg, purge all, and move the solid to have the wcs origin where you want it.
    for catalogs i then put all of one type (such as equal tees) in the one file (keep them as blocks)
    this makes it much easier to manage and select from the cat builder.
    ps you dont need to remodel everything, i pull most of my stuff from the content centre
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Member
    atul_0775
    12-03-2012 02:07 AM in reply to: agutak
    same problem i face. i am make one of model in plant 3d and make block then used plantpartconvert command and set the ip point (as per plant3d vedio shown) and when go to catlogeditor set all point. and save part not to config with part.png file.
