• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Display Configuration - Orthos
    755 Views, 18 Replies
    09-27-2012 11:24 AM
    I created a structural drawing by AutoCAD Structural Detailing Software and then Xref it to Autodesk Plant.
    When I tried to prepare orthos with the casual manner but I got these lines in themiddles of different walls and pads.
    Any help on how to remove them?
    Thank you
    Nawfel
     NB: see attached picture as example
    Please use plain text.
    Product Support
    Re: Display Configuration - Orthos
    10-02-2012 10:45 AM in reply to: nawfel.bouzayani
    Have you refered to the AutoCAD Structural Detailing Services and Support Page?
    AutoCAD Plant 3D 2013 Object Enablers.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19165270&linkID=12952913
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    10-04-2012 01:07 PM in reply to: quentin.contreras
    Thank you for answering,
    I have already that updates but no success.
    Thank you
    Nawfel
    10-12-2012 07:11 AM in reply to: nawfel.bouzayani
    Same issue here. The only difference is that I received the steel model from Tekla. It gives the same result as you. I did not found a solution yet.
    Product Support
    10-30-2012 02:07 PM in reply to: nawfel.bouzayani
    Have you verified if you have the AutoCAD Structural Detailing object enablers installed as well?
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18968562&linkID=9240618
    If that does not work, can you attach your drawing file so I can test it for the same results you are getting?
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Mentor
    Rich.O.3d
    10-30-2012 07:18 PM in reply to: nawfel.bouzayani
    couple of extra questions to help clarify the problem
    are they steel pieces, they look more like a concrete slab to me.
    did you use ASD or export from Revit to create them
    when you xreffed into your plant model, did you add the ASD file to the plant project?
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    10-31-2012 07:27 AM in reply to: Rich.O.3d
    the structural drawing consist of steel structural frame and concrete walls and pads.
    I created the drawings in 3D plant design and modify it in ASD to be able to adapt it to 3D.
    so these structural drawings were modified in ASD.
    Thank you
    Product Support
    10-31-2012 10:15 AM in reply to: nawfel.bouzayani
    Where is the XREF located? Did you copy the drawing to the Plant project and then xref the drawing into the Plant 3D drawing?
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    10-31-2012 08:00 PM in reply to: nawfel.bouzayani
    All the 3d dwgs are located in the 3d folder. I didn't check if the ask enabler is installed
    Valued Mentor
    Rich.O.3d
    10-31-2012 09:15 PM in reply to: nawfel.bouzayani
    which one...the 3d foder in windows explorer, or the 3d folder in the plant3d project browser
    refer attached
    hmmm..just noticed something...it may be your workflow thats causing the issue
    you said earlier that you created them in plant and then modified in ASD
    you cant edit the plant steel and concrete in ASD...did you sdnf out, then bring into revit, then link to ASD
    otherwise you will have to 'recreate' the steel in ASD.
    CAD Management 101:
