• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    luoyong20061289
    Delete drawings from project manager
    226 Views, 2 Replies
    12-19-2011 12:01 AM
    Hi, there,
    i'm a little bit confused here. when i create serval isometrics, all the isometric dwg files will be listed in the project manager. but when i delete isometrics dwg file from  project manager, the deleted isometric file is still listed in the project manager. is there something wrong about refreshing? what's worse, the deleted file can be still  opened ?  restart software, the deleted files disappeared,is this a bug or something? when i delete an ortho drawing from project manager ,the file disappeared right away. what's more,even i delete files from project manager,all deleted files are still located in my project folder. aka, i can't delete files from project manager directly.
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Delete drawings from project manager
    12-19-2011 01:44 AM in reply to: luoyong20061289
    When "removing" files from the project manager, they are removed from the project, but yes, the actual files are left there. I suppose its a sort of security backup that if its done by accident, the actual file isn't removed.
    When you remove a drawing from the Isometrics Tab, you need to pick the "Group by" button at the top of the pallete and the whole list is refreshed.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    luoyong20061289
    12-19-2011 04:52 AM in reply to: TomislavGolubovic
    Tomislav,
    Thank you for your information.That really helps me out.
