AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Custom Stub-in to elbows
- Highlight
- Email to a Friend
I have tried to make stub-ins in elbows for long thermo wells since 2011 release, and it seems like it's still not possible in 2013 release. Someone knows of a workaround to this?
Snip below illustrates where i would like to make the stub in: (Note that it's not connected in my example)
Re: Custom Stub-in to elbows
- Highlight
- Email to a Friend
Click the + grip off the corner of the elbow, hit S for Size and enter the size you want. THe insertion options are somewhat limited, but you can use the connectionoffset option to move it up our down on the elbow.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Highlight
- Email to a Friend
Hi dave:
I want to show the connection offset value on the iso to reduce the counculation work from the connection coordination, is there any possible way to config?
Thanks a lot !
- Highlight
- Email to a Friend
Thanks Dave,
I managed to get it right on a horizontal pipe that turns upwards. Then I tried on a horisontal bend (which did not work), and then I tried to continue on the first pipe run (see attached picture).
In both cases I use your method with "connectionoffseT" and I use distance: -((Bend radius)/2)
Slightly confused ![]()
- Highlight
- Email to a Friend
Hmm.
Seems like the original post were posted from my suscription-center login which is my real name.
Regards
Joachim
- Highlight
- Email to a Friend
Yea, it doesn't seem like there are enough options on the offset.
Isaiah 57:15
ECAD, Inc.
