• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    New Member
    joachim.ohlschlagel
    Custom Stub-in to elbows
    226 Views, 5 Replies
    01-24-2013 12:03 AM
    I have tried to make stub-ins in elbows for long thermo wells since 2011 release, and it seems like it's still not possible in 2013 release. Someone knows of a workaround to this?
    Snip below illustrates where i would like to make the stub in: (Note that it's not connected in my example)
    Please use plain text.
    dave.wolfe
    Re: Custom Stub-in to elbows
    01-24-2013 06:46 AM in reply to: joachim.ohlschlagel
    Click the + grip off the corner of the elbow, hit S for Size and enter the size you want.   THe insertion options are somewhat limited, but you can use the connectionoffset option to move it up our down on the elbow.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    New Member
    liuyong816
    01-24-2013 05:29 PM in reply to: dave.wolfe
    Hi dave:
         I want to show the connection offset value on the iso to reduce the counculation work from the connection coordination, is there any possible way to config?
         Thanks a lot !
    Active Contributor
    Layout-Bob
    01-27-2013 11:17 PM in reply to: joachim.ohlschlagel
    Thanks Dave,
    I managed to get it right on a horizontal pipe that turns upwards. Then I tried on a horisontal bend (which did not work), and then I tried to continue on the first pipe run (see attached picture).
    In both cases I use your method with "connectionoffseT" and I use distance: -((Bend radius)/2)
    Slightly confused :smileyfrustrated:
    Active Contributor
    Layout-Bob
    01-28-2013 01:22 AM in reply to: Layout-Bob
    Hmm.
    Seems like the original post were posted from my suscription-center login which is my real name.
    Regards
    Joachim
    dave.wolfe
    01-28-2013 07:10 AM in reply to: Layout-Bob
    Yea, it doesn't seem like there are enough options on the offset.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
