AutoCAD Plant 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Custom Part Valve
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
393 Views, 2 Replies
04-27-2010 02:21 AM
I have a question.
How can I make a custom valve and modify the End Type to FL and the Facing to RF.
I have tried but this items are blocked.
Re: Custom Part Valve
Options
- Highlight
- Email to a Friend
04-27-2010 05:41 AM in reply to:
abilioramos
These fields cannot be modified and defined out of the box as "Universal End Type", meaning could connect with any other end types. If you need to connect this Univesal_ET to a flange, then certain changes to the project setup, Plant 3D DWG Settings, Connections, Joint Settings are required. First modify the AutoFlange and remove Universal_ET from End 2. Next Add a new Joint, say UniversalFlanged, and select Universal_ET as End 1 and FL as End 2. Under Fasteners, select Gasket and Bolt Set. Under Property matches select Nominal diameter and then click the Add button to add the joint. OK to close project setup. Now in the model, you can place a custom valve and then add flanges to it. Note that when a custom valve is inserted to a pipeline flanges will not be placed automatically. This is because of a joint settings called Placeholder in project setup which makes connection between Universal_ET and all other end types valid. So with the Placeholder, Universal_ET and PE or BE or SW is valid connection and it will not add flanges. So delete the pipe, add flanges from tool palette or spec viewer and then add pipes to finish. Screen snapshots are attached for clarity.
Thanks, Siva (Autodesk)
Siva Thankappan
Technical Sales, Plant Solutions, Asia Pacific
Autodesk Singapore
Siva Thankappan
Autodesk Singapore
Options
- Highlight
- Email to a Friend
04-27-2010 05:43 AM in reply to:
abilioramos
This is for second screenshot.
Siva Thankappan
Autodesk Singapore
Siva Thankappan
Autodesk Singapore
