AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Custom Part Problems
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Since the 2012 version is almost here. I re-installed the autocad Plant 2011 demo version to suggest it to my superiors. Currently we do not use programs of this kind.
One of the things that I should demonstrate is that we will be able to use our blocks library.
To do this I decided to create a metric Project and create a custom part
The steps that I followed are:
- Inserted the block
- Convert the block using the plantpartconverter command
- Created the Custom Part using the plantcustompart command
- Completed the settings
- Inserted the custom part
The problem that I have is that I can not connect any other element to the custom part created
See pictures attached.
I followed the steps suggested on the help and I do not find what I am doing wrong.
Could you help?
Thank you in advance.
Max
Re: Custom Part Problems
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It worked. Thanks
Max
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a same issue and I did what you mention here. but how can I change type of spec when I import custom block.
