• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    JRPalmer
    Creating Pipe Saddles
    230 Views, 2 Replies
    11-29-2011 11:39 AM
    I was trying to create a pipe saddle for fibreglass piping. I thought the easiest way was to modify an olet so that one end is BELL and the other is something. I was going to chance it to BELL but that did not seem right.
    What should my end types be so that it connects to the pipe.
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Creating Pipe Saddles
    11-29-2011 02:15 PM in reply to: JRPalmer
    Whatever you want it to be in the Project Configuration. Add your end types in the Joint Settings dialog box.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Product Support
    jason.drew
    12-20-2011 02:33 PM in reply to: JRPalmer
    The BELL endtype is intended for bell and spigot connections so the connection/joint rules in Plant 3D wouldn't make the connection properly.
    Is this part for a pipe saddle, as in a support? Or something similar to a reinforcing saddle?
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
