• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    New Member
    Create ortho sections other than North/South/West or East directions
    302 Views, 2 Replies
    09-27-2012 06:05 PM
    I just want to know if there is a way of creating ortho section views in say NE or NW, SW or SE direction.
    EG
    Please use plain text.
    Valued Mentor
    JohnHolder
    Re: Create ortho sections other than North/South/West or East directions
    09-28-2012 08:58 AM in reply to: edgeplant3d
    Rotate the model 45 deg is the only way I think.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Employee
    10-09-2012 01:50 PM in reply to: JohnHolder
    The work flow I have used here on many cases is to set up some "dummy" models and xref the models you require. Then rotate the entire set of objects to where you want it. This file is not to be used for design, nothing would connect to the ports at all.
    Then when running your Ortho, use the "Dummy" model.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Jarrod Mudford
    Plant Solutions Consultant
    Global Services
