• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    Converting Cadworx Specs error
    300 Views, 2 Replies
    09-30-2011 05:50 AM
    I'm new to Plant 3D 2012, I've been using the Cadworx products for years. I'm currently trying to comvert a spec from Cadworx Plant 2012 with no success.
    I go through the coversion process but it doesn't do the conversion, In the migration-log.txt file I get a "Failure could not open coverted csv data files. Any ideas how to solve this problem?
    Please use plain text.
    Re: Converting Cadworx Specs error
    09-30-2011 08:46 AM in reply to: rwilliamson
    The 2 biggest reasons I see people having trouble converting specs are A: they may or may not have the proper access rights to the folders and B: picking the wrong path for the standard library.  Here's some screen shots from an article we are writing on the process if this helps.  Note the standard library path is NOT the LIB-MM folder, but rather the upper leverl plant folder.
    Hope this helps, let me know if you have any questions or if it's still giving you grief and we can sort it out a little more.
    Kyle Pope
    Process and Power Specialist
    ECAD, Inc
    Our Blog
    www.pdoteam.com
    New Member
    02-04-2013 08:09 AM in reply to: rwilliamson
    I do get the same error message but even when I use the file structure as described above. Also the description and folder structure is different to the one described in the Plant3D help. In the help everything is in one folder?!
