AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Convert settings Autoplant catalog
- Highlight
- Email to a Friend
- Report Inappropriate Content
I'm trying to import a Autoplant catalog into Plant3D using the Convert option in Speceditor.
For some components I need to use the pulled bend (CPBP) component in P3D. To achive this i'm trying to adjust the Geometry Mapping in the Convert settings for Autoplant. I need to change the 'CPB - BW' setting to 'CPBP - BW'.
However, although I can delete the exisitng items, when I try to add an extra item by typing 'CPBP' in the 'Add script name' fleld and either use the Tab key or clicking the '+', the entry disappears and the field stays empty, or I get an error: "Please enter a valid name"
Is this a bug, or am I doing something wrong?
See also attached screenshot
Re: Convert settings Autoplant catalog
- Highlight
- Email to a Friend
Hi There,
This is a bug, but there is a work around. What you will need to do is edit inside the ATPtoP3DGeometryMapping.xml
Firstly make sure to make a copy of the ATPtoP3DGeometryMapping.xml before editing
Inside the xml file search for "AT_ELBOW_LR_90"
Then you will add in the following (underneath the line <ScriptMatchCollection>):
<P3dScriptMatch>
<Name>CPBP</Name>
<PropertyValues>
<string>BW</string>
</PropertyValues>
</P3dScriptMatch>
So it should look like the attached screen shot.
Then when you re open the mapping settings for the AutoPlant to AutoCAD Plant 3D it will look like the 2nd image I have attached.
Hope this helps.
Tarryn
- Highlight
- Email to a Friend
Tarryn,
Thanks a lot, that helps.
