• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Plant 3D
    Active Contributor
    ashley.walker
    Connection Failed
    429 Views, 2 Replies
    08-09-2012 09:30 PM
    Hello everyone,
    I am haveing troubles setting up a project to use MS SQL. When I create a new project (or try and convert one) I go through all the prompts until I get to the screen that lets me choose the database type. When I press the downwards arrow to select the SQL server, it automatically detects about 12 SQL servers running on the network. I select the correct one (the one I want to use) and press "Test Connection" Each time I get the same error message:
    Connection Failed
    Your test connection to the specified server has failed. Please try again.
    You can see in the image that the Server is actually working, (SQL Management studio connecting into the server, on another physical machine). It is the only instance of SQL running on the server and a clean install of the server (SQL and OS).
    This error also happens to all other SQL servers that I attempt to connect to (even the one on my workstation) and even happens across multiple workstations. Does anyone know of a solution for this?
    Plant 3D 2013 Premium
    Windows 7 x64
    Please use plain text.
    Valued Contributor
    neonade
    Re: Connection Failed
    08-15-2012 08:01 PM in reply to: ashley.walker
    Hi ashley, have you tried looking at this website as your guide?
    http://www.davetyner.com/au-2011-classes/autocad-plant-3d-sqlite-to-microsoft-sql-server-%C2%AE-jaso...
    Active Contributor
    ashley.walker
    08-15-2012 08:52 PM in reply to: neonade
    I have solved this about an hour ago (after days of head aches trying to get it going!)
    To start I installed DotNet (.Net) version 4 This may or may not have been what made it work, I was promted to do this after reading an Microsoft Document on SQL and .Net The document explained that progrmas require the same .Net version in order to comunicate over TCP/IP. And it would seem that AutoCAD 2013 uses .Net 4 (as it is installed as a prerequisite) and SQL 2008 R2 uses (as defualt) .Net 3.5
    Afterwards I installed the role/service of IIS 7
    Inside of IIS 7 I created a Database connection string to the Master Database.
    And then I also had the Windows Authenticaiton Enabled as well as Anonymous Authentication.
    After a reboot, AutoCAD Plant 3D gave me a false positive (same as the image posted before) but this time was able to connect to the server and make the databases.
    I will post a more detailed version with screen shots when I can get some more time.
