AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Concentric , Eccentric Reducers and Reducing Tees
- Highlight
- Email to a Friend
How do you input the data in the spec Editor 2012 to show the difference in schedule of pipe fittings. For example, a concentric reducer 4" SCH 80 LE x SCH STD SE.
Alex Salcido
Re: Concentric , Eccentric Reducers and Reducing Tees
- Highlight
- Email to a Friend
So does anyone have anything about this?
- Highlight
- Email to a Friend
Typically you would use the "Batch Assign Long Description Styles" function of Spec Editor to configure a new format or string for the properties you would need.
I attempted to configure the long description as you mentioned above. However, I wasn't able to use the size field for the second part of the string.
I am assuming you would want something similar to this for a reducer that changes in size and schedule (as an example):
4" SCH 80 LE x 6" SCH STD SE
Would be something like:
<Nominal Diameter>" SCH <Schedule> LE x <Nominal Diameter>" SCH <Schedule> SE
So there are two property fields for size and schedule in the spec, but the long description style editor only recognized the first entry for size and schedule.
The workaround I tried was to create 4 new fields:
SIZE1
SIZE2
SCH1
SCH2
But unfortunately you cannot use custom property fields in the long descriptions.
I have submitted this issue to the development team.
Thank you,
Jason Drew
Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
- Highlight
- Email to a Friend
Thanks Jason. Just wanted to make sure I wasn't missing something.
