• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Accepted Solution
    Concentric, Eccentric Reducers and Reducing Tees
    723 Views, 3 Replies
    01-17-2012 09:48 AM
    How do you input the data in the spec Editor 2012 to show the difference in schedule of pipe fittings.  For example, a concentric reducer 4" SCH 80 LE x SCH STD SE.
    Alex Salcido
    Please use plain text.
    Re: Concentric, Eccentric Reducers and Reducing Tees
    01-24-2012 05:34 PM in reply to: asalcido
    So does anyone have anything about this?
    Product Support
    jason.drew
    01-25-2012 03:56 PM in reply to: asalcido
    Typically you would use the "Batch Assign Long Description Styles" function of Spec Editor to configure a new format or string for the properties you would need.
    I attempted to configure the long description as you mentioned above. However, I wasn't able to use the size field for the second part of the string.
    I am assuming you would want something similar to this for a reducer that changes in size and schedule (as an example):
    4" SCH 80 LE x 6" SCH STD SE
    Would be something like:
    <Nominal Diameter>" SCH <Schedule> LE x <Nominal Diameter>" SCH <Schedule> SE
    So there are two property fields for size and schedule in the spec, but the long description style editor only recognized the first entry for size and schedule.
    The workaround I tried was to create 4 new fields:
    SIZE1
    SIZE2
    SCH1
    SCH2
    But unfortunately you cannot use custom property fields in the long descriptions.
    I have submitted this issue to the development team.
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
    01-25-2012 04:51 PM in reply to: jason.drew
    Thanks Jason.  Just wanted to make sure I wasn't missing something.
