• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    JVNows
    Color overrides 'material' from some piping elements, only in assembly.
    231 Views, 2 Replies
    05-26-2011 07:47 AM
    Hi all,
    I have a drawing with piping, I've given all the parts a material and tested it in the wame drawing with a render, giving perfect results, how I'd expect it.
    If I Xref (or even import as a block) this piping drawing into our assembly, certain piping elements (bends, T's, ...) get the color of their layer, not the material I've given them.
    Thanks in advance!
    screenshots attached
    Please use plain text.
    Valued Contributor
    Re: Color overrides 'material' from some piping elements, only in assembly.
    06-02-2011 11:02 AM in reply to: JVNows
    I don't know why the program do this in Navisworks current the same.
     One question how do you do the circular railing?
    Active Member
    Mudbay
    09-12-2012 04:22 AM in reply to: JVNows
    Hi, I got the same problem. Every pipe part that is straight, the steel material is shown correct when rendering, but all Tees, bends and so on still got the gound color even though the properties say it's got the steel texture.
    /Mattias
