• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    JohnHolder
    Accepted Solution
    Changing the insertion point of an ortho view? ( create ortho view )
    100 Views, 1 Replies
    01-29-2013 11:05 AM
    Is there a command to change the insertion point of an ortho?
    currently it defaults to the bottom left corner, I want to change it to the center.
    I place the ortho down then select the mid between two points to replace each and every ortho I place, which is a lot of wasted time.
    John.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Please use plain text.
    Product Support
    Re: Changing the insertion point of an ortho view? ( create ortho view )
    02-01-2013 04:11 AM in reply to: JohnHolder
    HI,
    It is not possible to change the default insertion point of the ortho viewport from the bottom left point.
    You can post a feature enhancement request here:
    Product Feedback
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
