The shared content folder can be set during installation.
During install (single user or when building a network deployment), use Custom Installation, and select Local Content. You can then enter the the network location. UNfortunately this option is not available in maintenance mode of the installer; it can only be set during first install so a reinstall can be required to change this.
Adding link to related discussion here (message 😎
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Custom-equipment-nozzles/m-p/2878190#M1835
