• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    Changing nodes on existing pipe spec blocks
    78 Views, 3 Replies
    09-17-2012 01:46 PM
    I was wondering i there is a way to change the nodes/ports on existing parts in catalogs in the spec editor.
    I've run into a problem where one of the nodes/ports is in the middle of the part and won't connect properly when trying to route.
    Any help is appreciated. Thanks,
    Chris
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Changing nodes on existing pipe spec blocks
    09-17-2012 03:22 PM in reply to: Christopher_Lam
    In the Spec and Catalog Editor, click on the top right where the tab says "Catalog Editor" and then load the catalog that the part has come from.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Active Member
    09-18-2012 05:49 AM in reply to: TomislavGolubovic
    Sorry I meant, is there a way where you can change the port location on the model/block? One of my ports is in the middle of my part when I set the parameters and when I try to connect it to something it connects improperly.
    Employee
    TomislavGolubovic
    09-18-2012 12:38 PM in reply to: Christopher_Lam
    Got a screenshot please?
    Tomislav Golubovic
    Autodesk, Inc.
