is possible to change directory of nozzle catalog? Because I want to work only en server. And remove "AutoCAD Plant3D Content" folder from my PC.
Solved by RSFAdsk. Go to Solution.
Hello, in AP3D 2011 you can set the content folder location only during initial install.
But there is a post that describes the registry values associated with this setting here: http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Custom-equipment-nozzles/m-p/2878190#M1835.
