• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Ahmed1081975
    Centrifugal Pump Issue
    313 Views, 3 Replies
    12-10-2012 10:21 AM
    Dear All,
    I have Pump the discharge not same center line of the suction how I will get
    For more clarification refer to the attached files
    Ahmed Helal
    Please use plain text.
    Product Support
    gersteb
    Re: Centrifugal Pump Issue
    12-12-2012 05:40 AM in reply to: Ahmed1081975
    Hi Ahmed,
    I understand that you have a model of a pump and you want to use it as a Plant 3D equipment. Do you have the new user-defined pump as an AutoCAD model or as Inventor assembly? Depending on that you will use command PLANTEQUIPMENTCONVERT (AutoCAD model) or PLANTINVENTOREQUIPMENTCONVERT (Inventor) to convert this model to a Plant 3D equipment.
    Regards
    Bernd
    Bernd Gerstenberger
    Senior Support Specialist
    Product Support
    Ahmed1081975
    12-15-2012 12:02 AM in reply to: gersteb
    Thanks for your reply
    Actually those two issues I know about it my point is should be including the programs because I have for each model draw first in 3d model and converting witch is cost me a big time I was hope the another easy  solution.
    Ahmed Helal
    Product Support
    gersteb
    12-17-2012 03:05 AM in reply to: Ahmed1081975
    Hi Ahmed,
    Currently we don't have here a big library here for equipments. And PLANTEQUIPMENTCREATE creates more general equipments, not such specific as you want. So I'm sorry to say that you have to use either PLANTEQUIPMENTCONVERT for AutoCAD models or PLANTINVENTOREQUIPMENTCONVERT for Inventor assemblies.
    Regards
    Bernd
    Bernd Gerstenberger
    Product Support
