• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Plant 3D
    Valued Contributor
    Gabriel.N
    CUT Problem
    180 Views, 4 Replies
    05-10-2012 01:51 PM
    Hey,
    This is something that since always happens to me.
    When I'm in perspective view with a short focal length like 20mm, objects that are closer are cut of vision.
    Look the attached image.
    Is there any way to fix this?
    Please use plain text.
    Valued Contributor
    Gabriel.N
    Re: CUT Problem
    05-21-2012 07:56 AM in reply to: Gabriel.N
    Someone, somebody, anyone knows how to fix this?
    Product Support
    Re: CUT Problem
    05-31-2012 02:45 AM in reply to: Gabriel.N
    I can't reproduce this issue.
    The first thing to try is an update of your graphics driver.
    http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Employee
    KenFauver
    Re: CUT Problem
    05-31-2012 05:57 PM in reply to: Gabriel.N
    This happens when trying to view the model in perspective while clipping is on. If you turn clipping off it will go away. This is not a Plant 3D issue. It is an AutoCAD function.
    New Member
    Re: CUT Problem
    06-01-2012 01:05 AM in reply to: Gabriel.N
    That's been a very frustrating problem for me also, thanks for clearing that up!! :smileyhappy:
