• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    RNDPIS
    Basic doubts about AutoCAD Plant 3D
    439 Views, 6 Replies
    02-20-2013 11:17 PM
    We have few basic doubts,which needs to be sorted out for AutoCAD Plant 3D suite:
    1.      How to import files from other softwares like TSI or revit
    2.      What are the export /Import methods and settings
    3.      How to edit existing database depending on project requirement
    4.      P&ID diagram settings and editing
    5.      How to create equipment model based on project submittals
    6.      What is production ISO
    7.      How to create and edit shop drawings
    Please use plain text.
    Valued Contributor
    Betreff: Basic doubts about AutoCAD Plant 3D
    02-21-2013 12:39 AM in reply to: RNDPIS
    a lot of questions .... mayby its time to vist a training  or read on of the books ...
    cw
    attila_vallyon
    02-21-2013 02:16 AM in reply to: cadwomen
    Completely agreed!
    You should start a proper training or go through a training book before start asking these kind of questions!
    All of your questions will be answered than.
    Attila Vallyon
    RNDPIS
    Re: Basic doubts about AutoCAD Plant 3D
    02-21-2013 02:33 AM in reply to: RNDPIS
    Thank for the thaught. If you have the answer then it would be very helpful for both of us. We are waiting for your valuable reply:smileyhappy:
    *Expert Elite*
    dgorsman
    02-21-2013 12:05 PM in reply to: RNDPIS
    Thats a little too extensive to be able to cover properly in an internet forum.  If you haven't already, get a reseller to come in for a demonstration.  Make sure they are aware of your specific requirements (such as importing from Revit, which *all* programs have problems with) so they can tailor the presentation properly.  In addition maintain industry contacts with other users in your area.  There may be other users/companies who would be willing to visit or let you visit for a first-hand non-sales review.
    Adopt. Adapt. Overcome. Or be overcome.
    Active Contributor
    rchiasson
    02-25-2013 05:46 PM in reply to: RNDPIS
    Agreed, these are questions suited for demos and training. They are lengthy How To questions. The answer to all of these would be to contact a reseller and schedule a demo, probably explain that you have some detailed quesitons and they will be able to tailor a demo, or schedule a longer demo with time for indepth Q&A.
    Employee
    TomislavGolubovic
    02-25-2013 07:01 PM in reply to: RNDPIS
    I'll help with some answers
    Q1. How to import files from other softwares like TSI or revit
    A1. Not knowing what TSI is, I can't answer that. In regards to Revit, you would export the Revit model to .dwg format, and use that as an XREF against your piping model.
    Q2. What are the export /Import methods and settings
    A2. In regards to what? DWG's or database?
    Q3. How to edit existing database depending on project requirement
    A3. Not 100% sure on what you're asking here. If the project changes? Project variables? Specs? Models?
    Q4. P&ID diagram settings and editing
    A4. A draftsperson edits and creates P&ID's inside the project.
    Q5. How to create equipment model based on project submittals
    A5: There are three ways of creating equipment. The first is by using the form provided in the software to create equipment, in which you can export templates. The second is to convert an AutoCAD 3D Model of the part. The third way is to convert an Inventor .adsk file to a piece of equipment.
    Q6. What is production ISO
    A6. An Isometric drawing that goes to a factory to be built. Its a 2d representation of the pipe run from the model, it also contains a Bill of Materials.
    Q7. How to create and edit shop drawings
    A7. Shop drawings of what?
    Hope this helps.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
