• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Plant 3D
    Member
    diegorgfaria
    BOP Tag
    221 Views, 3 Replies
    04-09-2012 09:28 AM
    Is there a way to customize a tag format in order to show the BOP in an Ortho View?
    I tried to create a new tag format, but I couldn't find the parameter on the "Select Class Properties" box under Pipe (attached file).
    TIA.
    Please use plain text.
    Product Support
    jason.drew
    Re: BOP Tag
    04-16-2012 02:21 PM in reply to: diegorgfaria
    Using "Position Z" would get you close, but that's the COP elevation.
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
    Employee
    Re: BOP Tag
    04-18-2012 10:54 AM in reply to: jason.drew
    Please see this discussion entry. It may be what you're looking for:
    http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Elevation-in-ORTHOVIEW/td-p/3172994
    Peter Quinn
    Senior Product Manager
    Autodesk, Inc.
    Member
    diegorgfaria
    Re: BOP Tag
    04-20-2012 11:11 AM in reply to: PeterQuinn
    Thanks for the replies.
    I consulted the provided link, but my problem is a bit different. We have already modeled the entire project, and, if I'm not mistaken, the routine in the link works for new elements or elements modified after the creation of the triggers.
    Is there a similar solution to update all the Pipe Run Components (or just pipes actually) that we've already created?
    Regards.
