• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Ahmed1081975
    BONDSTRAND Pipes and Fittings Catalog
    540 Views, 6 Replies
    11-18-2012 07:59 PM
    Dear Autodesk Supports,
    Regarding your last Catalog (BONDSTRAND Pipes and Fittings Catalog) there are end connection Call KLF & KLM &
    MDO..., all those connection not available in the program itself but those connection in your attachment
    (DefultConnectiorsConfige.xml). in the attached file screen shot for my issue.
    Please Advice
    Ahmed Helal
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    Re: BONDSTRAND Pipes and Fittings Catalog
    11-19-2012 02:36 PM in reply to: Ahmed1081975
    did you follow the instructions in the readme file.
    you also need to replace the DefaultConnectorsConfig.xml
    if you did then it may be due to a language version (ill let one of the devs chime in if thats the case)
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Product Support
    Venkatesan.A
    11-19-2012 06:39 PM in reply to: Ahmed1081975
    Ahmed,
    First you need to be aware of the connection rules defined by Bondstrand like KLF should be connected to KLM ends etc.,
    KLM and KLF means Key lock male and female joints respectively, and DOM, DOF means Double O ring Male and female joints.
    As rich mentioned the bondstrand content pack has the "DefaultConnectorsConfig.xml" inside which such rules from bondstrand are predefined for you to start using right away after you download this content pack.
    Please follow the instruction in the readme file and you should have no problem i guess.
    Venkatesan.A
    Support Specialist
    Product Support
    Ahmed1081975
    11-19-2012 08:42 PM in reply to: Rich.O.3d
    you have to add also those connection in the Endcoding.xml file
    For this catalog, there are some new Endtypes added as below,
    DOM - Double O-ring Male
    DOMK - Double O-ring Male w/key
    DOF - Double O-ring Female
    KLF - Key Lock Female
    KLM - Key Lock Male
    You can use the command “PLANTENDCODES” to add these endtypes in AutoCAD Plant3D
    Product Support
    Venkatesan.A
    11-20-2012 07:16 PM in reply to: Ahmed1081975
    Ofcourse you should, the help document link has been provided in the readme file to do that.
    Venkatesan.A
    Support Specialist
    Product Support
    Ahmed1081975
    11-20-2012 08:10 PM in reply to: Ahmed1081975
    Thanks Very much
    Problem Solved
    Ahmed Helal
    Valued Mentor
    Rich.O.3d
    11-23-2012 12:45 AM in reply to: Ahmed1081975
    well that was an odd thread...the question got a kudos and the highlited solution tick is located three or four posts after the initial solution!
    CAD Management 101:
