• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    AutoCD Plant 3D - ISO BOM Configuration
    231 Views, 2 Replies
    02-12-2013 01:02 AM
    Hi All
    In the Bill Of Materials Table is there a possible way to change the Text from CAPS to smalls?
    As well as in the size field to change the delimiter "X" to "x", everytime w have to edit this as this is what the client wants and is paying for? Each time our team has to manually edit this?
    Have already edited the IsoConfig.xml file
    or maybe i did not have the correct details of what to config . . .
    If you could help would greatly appreciate
    Thanks in Advance
    Best Regards
    Richad
    Please use plain text.
    Member
    Re: AutoCD Plant 3D - ISO BOM Configuration
    02-14-2013 11:26 AM in reply to: CaveManCode
    in your title block setup double click the field (text) and under format it gives you case options
    02-15-2013 04:32 AM in reply to: CaveManCode
    Hi There
    Thanks for the feed back, but these ooptions or properties on the Table do not function.
    When the isogens are spooled, somehow the default setting is all caps lock, no matter how you have configured the table in the iso.dwt file?
    so everthing comes out in caps?
    Appreciate the reply - maybe there is some other setting that would allow the iso.dwt table to take preference?
    Regards
    Richard
