AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
AutoCAD Plant 3D - Structure - Add New Items
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Good Day All
Does anyone have a tutorial on how one adds different shape standards to AutoCADPlant 3D structural.
We want to add our Native SANS steel sections to AutoCAD Plant 3D?
Any advice, tuturial reference, assistance welcome
Thanks in advamce
Regards
Richard
Re: AutoCAD Plant 3D - Structure - Add New Items
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is available Content Packs on Plant Exchange you can download. But at the moment there is now way to publish your own Structural Members. From Plant Exchange you can request a Content Pack and it will be placed in a list to be created by Autodesk.
Jarrod Mudford
Plant Solutions Consultant
Global Services
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the information
Unfortunatly did not find any content packs for SANS steel sections.
I see you work for Autodesk, here is a requsest . . .
Can you send me the Table, File and Data Hierarchical Structure so that i can create a .Net User Interface to add data?
Did you hear that Mercedes Benz now sells cars without steering wheels? They tried to use AutoDesk Software but could not add the specifications in to design the Steering Wheel!!
Appreciate your reply
Best Regards
Richard
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Richard,
Was wondering if you came right with the SA steel content. i'm in the same boat.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Clifford
Sadly Not, We used ASD (AutoCAD Structural Detailing) instead.
I did hear that Modena compiled the steel sections for SANS in Plant 3D "say this under correction" as i have never checked this, but as i understood this was for retail from them?
On the download center i only came accross someone that had edited the Australian Steel sections released 2010, i did email the person but to no avail, did not recieve a reply with the method in which it could be done?
Best of luck to come right with this.
Regards
Richard
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Richard,
Thanks for the response. I'm new to the Plant Design Suite, and I must say
the lack of SA content is frustrating.
Where did you get your SA content for ASD?
Kind regards
Clifford McClure
TDF Projects and Equipment
P.O. Box 20758
Durban North
KZN, 4016
South Africa
Tel + 27 31 9103527
Tel/Fax + 27 31 5727652
Fax 0865399982
Cell + 27 83 3090623
E-mail clifford@tdfprojects.com
Website: http://www.tdfprojects.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi There
To find the SANS sections in ASD please review Image
Once this is loaded you can select the various steel section required.
The negatives using ASD is that the geometry is NOT 3D solids, The ASD model has to be exported as a .SAT to be able to get used in the Orthographic DWG in plant 3D. Review image below as well . . .
ASD has got a utility to export to ACIS, but we found that this would also export non solid objects. with these entities in the model in Plant 3D, this caused the Orthographic to crash? This was not consistent however . . .
The better alternative was to use the File > Export > Other Formats > SAT (This only exports true 3D solid objects.)
As you can see there is a little work around for this . . . but ASD work fast and effctive for generating Steel Structures for plant design.
If someone reads this and has better solutions - please post comments.
Cheers Mate
Regards
Richard
