• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    ybogdanov
    Re: AutoCAD Plant 3D Catalog Builder (Beta) is available now
    10-20-2011 11:43 PM in reply to: EileenForan
    Win 7 prof 64bit, work correctly
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Please use plain text.
    Valued Contributor
    10-21-2011 11:59 AM in reply to: rlpacle
    To install it, you need to unRar into your AP3D intalled folder, (Autocad Plant 3D english) and run it...
    and Voila!..it´s works..!
    Valued Mentor
    ybogdanov
    10-27-2011 06:27 AM in reply to: EileenForan
     In the case when I go to set the dimensions in the excel, in the column of OD (out diameter) I write the values in mm, for example:
     88,9 - for pipe DN80
    114,3 - for pipe DN100
    When I export this excel sheet from Catalog Builder to one exist catalog the program don't recognize "coma", the OD result diameters are:
    889
    1143
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Employee
    rajsekarpillai
    11-01-2011 01:16 AM in reply to: ybogdanov
    Currently, The Beta is only support period (".")delimiter.
    Thanks & Regards,
    S. R. Rajasekaran
    Product Manager
    Plant Solutions - AEC
    Valued Mentor
    ybogdanov
    11-01-2011 09:17 AM in reply to: rajsekarpillai
    Thanks & Regards,
    I was prove with "." delimiter and it don't work too.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Employee
    rajsekarpillai
    11-02-2011 12:04 AM in reply to: ybogdanov
    I think this could be the computer delimiter issue.
    Go to Control panel -> Region and Language -> click the Formats tab -> click the additional settings button -> change the “list separator” to “.”Instead of comma.
    If this doesn’t work, please attach your excel file and I will try at my end.
    Thanks & Regards,
    S. R. Rajasekaran
    Product Manager
    Valued Mentor
    ybogdanov
    11-02-2011 01:28 AM in reply to: ybogdanov
    This is the excel
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Active Contributor
    11-02-2011 08:18 AM in reply to: EileenForan
    When I try to start AutoCADPlant3DCatalogBuilder.exe Windows 7 64 German tells me that the program doesn't work anymore. The HowTo actually doesn't mention this AutoCADPlant3DCatalogBuilder.exe. So I'm wondering if it's needed at all.
    Thanks for hints
    Carsten
    Valued Mentor
    ybogdanov
    11-27-2011 11:44 AM in reply to: cbeinecke
    When the template are created with all objects of new catalog, and we create the excel, after one hour of defined the geometry of objects in excel I find that my nipple have all connection points together...( is imposible to define the each connection point separatly, one PL another FL for example). Which is the solution? Change the config in Catalog Builder and turn to create excel (purgeing my one hour of work)? Is posible to change only this object in CatalogBuilder and others sheets of excel don't touch, because have all geometry of objects defined.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    GeorgeKamieniecki
    02-07-2012 05:45 AM in reply to: EileenForan
    Hello Eileen,
     I dowloaded Catalog Builder and followed all the steps in the accompanying docx file.
    I was unable to run the testacpscript lisp program as mentioned in point 4 of the docx. This file does not appear to be available anywhere I have searched.
    Point 5 e in the docx reads:
     "Save the image to custom script folder. When user request the custom script images by image API, the image API will scan the custom script folder to fetch the images which meet requirement."
    Please elaborate on "request the custom script images by image API".
    Where does in fact TestScript component get accessed from? Plant3D? Spec Editor?
    I feel I am missing some background on how and where I can put Catalog Builder to use.
